Interior Lights Intermittent
Mike Ogara
Indianapolis
I searched but couldn’t find an answer to this. I just took delivery of a 2019 Expedition Limited. The rear interior lights (above the rear doors) seem to turn on and off intermittently. When they are on, the switch will not turn them off, but when they are off you can turn them on. I’m pretty sure I’m not doing anything wrong with the dome light switches because I previously has a 2018 Limited and never had this issue. Any ideas?
nate6966
US
Mine did the same thing, but it turned out to be my kids playing with them, turning them off and on independently, which overrode the driver controls (acts as reading lights for rear passengers)
M
Mike Ogara
Indianapolis
Bump. I still can't figure out the rear seat interior lights on my '19 Limited. They are randomly on when I drive the car. Neither the front master switch nor the switch that is on the light itself will not turn them off.
scottdm
Western PA
Any chance you have a door that isn't latching properly and it's causing the lights to come on/off intermittently?
M
Mike Ogara
Indianapolis
I don't think it's a door latch issue because there's no indication on the dash that the door is not fully closed, and the running boards always retract. I assume all of these systems are tied together. The dome light seems to be the only thing not behaving.
aggiegrad05
North Texas
Do the running boards retract when the vehicle is stationary, or only when you drive off? Because they will retract when you drive away even if the door is wide open.
(But I believe you're correct...if it was a latch issue I would think you'd get a dash alert.)
dirtydiamond
Same issue. Rear passenger 2nd row window light, 3rd row roof light and tailgate light will not shut off. All doors are closed. Tried WD-40 in all the door latches. All of the other lights will shut off with locking doors. The running boards operate correctly with opening and shutting each door.
Kirk Olson
West Fargo, ND
Were you guys ever able to get this solved? I just purchased a 2019 Expedition Max Limited and am having the exact same problem. Thanks
