dlyoung1
I have an '03 XLT 4.6L that has had an intermittent start issue that needs resolution. Occasionally, when you crank the engine it will fail to fire or require a very long (longer than I want to run the starter) crank time. If I "cycle" the key off/on and crank it again, it will ALWAYS fire immediately and run fine. Almost like it sometimes fails to give the "go" command to the fuel pump or the injectors? Never has given a CEL code of any kind related to fuel system. It's not a huge deal, but I don't want to go from Intermittent to Fail status!
