leaky sunroof
AlexExpy
Albany NY
Guys, my 05 expy has a leaky sunroof. Where to buy a new seal? And is it hard to replace just the seal? Thank you in advance.
AlexExpy
AlexExpy
Albany NY
Are you sure it's the seal and not the drain tubes stopped up?
Actually not sure but stuck my head up there to look around didn't see any thing suspicious.
How would one go about checking the drain tubes? TIA.
sgtowing
Supporting Members
Valrico, Fl
Use a blow gun with a needle tip and try to blow out the drains first. Most of the time, Its clogged drains that are the problem.
rexster314
Texas gulf coast
What he said, but use the air judiciously. You don't want them to blow off the sunroof using too much pressure. I don't remember exactly, but I think the holes are in the front corners
AlexExpy
AlexExpy
Albany NY
Thank you gents, I have never touched the sunroof before but will give it a try, thanks again for all the advises.
