Hi guys,
I have an 06 Limited and tow an enclosed 20ft car trailer that weights between 7,000 - 7,500lbs when loaded with car, tools, tires, etc. The rear sags quite a bit. The truck is equipped with the HD tow package and has the spring/shocks suspension setup - are any of you guys using some sort of leveling system?
Came across this at etrailer:
http://www.etrailer.com/Vehicle-Suspension/Ford/Expedition/2006/TFREXPB.html?vehicleid=20061010168
Looks like a pair of bump stops? Anyone using the above or a different system to help level the truck a bit that can chime in with some feedback? I'm also researching some WD hitches which should help a little bit, but I think that i definitely need something to help support the weight.
Thanks guys!
Thanks guys!
