Lifted Expedition ???? Shocks????
Bart Man
New Jersey
I have a 2-3" Leveling kit installed with Blistein HD shocks in the front, Does anybody know who makes a shock for this lift or is the stock ones Ok, Blistein say that they will work fine but it just does'nt make sence to me, I did get the correct shocks for the rear,(for the 2'' lift)The ride is alittle bouncy but I guss its from the keys,
walnuts4x4
Watertown, NY
you should be fine... most trucks I have helped lift with only body lift and leveling kit reused the stock shocks... i think maybe Procomp or fabtech make shocks for different size lifts.... but if your shocks still have travel in them you shouldn't have a problem
dgray69
upstate ny
rancho makes shocks for 2 to 4 inch lift in both the 5000 and 9000 series, they will give you the right amount of travel for the 2/3 level lift, i am running the 9000s on rear and 5000 on front, but changing them to 9000s soon, but the ones you have will work fine for every day driveing and even light off road, as long as your not jumping your truck, then you will blow the shaft clear through the housing, thats the prob i have now with the 5000 series, they are stock shocks
KWT2000
NINE MILE FALLS
zone off road products make 2" front lift shock part number is ZON4805.... two shocks and boots was $93 shipped to my door
henry98
niceville
i have the part #'s for exactly 2" lift rancho shocks for 97/02 ford expedition 4x4... i buy all my shocks by collpased and extended lengths so they function the way i want them to. let me know if you want them #'s :)
