Lifting a 2008 - Tire/wheel questions
B
briandye
So I was out messing with Forscan, since I got my new OBDII plug with the MS/HS switch. I wanted to turn the TPMS system off, and adjust my speedo, which was an option in the 2015-2017 section, so I figured it was worth a shot.
Didn’t match the data for adjusting the speedo, so that’ll still have to be a dealer trip, but I did manage to get TPMS turned off.
In my “field test” I went to drop a Tire down to about 20 PSI, and go for a drive. Come to find out, they had these damn tires at about 48 PSI! That probably explains the insanely harsh ride, feeling EVERY single pebble and piece of dirt on the road! I dropped them all to 35 for now, read quite a few Jeep and lifted truck forums where people were asking what pressure to run on the road. Ranges from 28-32ish on average from what I saw, with 35” tires. I personally feel like that’s too low, so I dropped them to 35 for now. Well see how she rides tomorrow morning on my way to work.
Sccritterkiller
SC
I run 28 psi in my jeep...it has leafs all the around so every little bit helps...
Adieu
SoCal
Wranglers weigh 2000 lbs less though
B
briandye
Yeah the more I dig into some of those threads, the more 28 seems to be the most common. Ill give them a shot at 35 tomorrow, and see how they feel. I don't really have anywhere to go today, and I don't really feel like leaving the house anyways lol
Adieu
SoCal
You're not wrong; but is it really necessary to have them at nearly 50 PSI?
Probably depends on whether you drive just yourself... or totally disregard the stickers and regularly pile in 2,000+ lbs of people and gear
B
briandye
Nope, just myself and occasionally another 300(?) pound coworker lol
A few days at 35, and the ride is night and day. Bump steer is probably not even half as bad as it was either. Win win.
I feel like the tire/road noise has gone down a little bit but that’s probably just in my head.
Sccritterkiller
SC
Good deal. I hope you didnt misunderstand my previous post...I wasn't implying that you should run your tires at 28psi...my intent was show you that you should experiment with your psi and recalibrating your speedo before jumping to a regear...my YJ is 4000 lbs less than my expy and only has 33s. No way I would run my expy on 28 psi unless I was out on the outer banx... in which case I run 25 psi on the sand..Glad to see your getting it dialed in.
B
briandye
Oh no I gotcha, that’s another thing I got from other forum posts, basically just expirament and see what feels best to you. One guy even described how to do a chalk test and basically test the tread wear pattern to get you the best pressure to get the most life out of the tires.
So update on the shifting:
I really feel like the trans needed to “adapt” or adjust its patterns. It’s shifting quite different now, (not in a bad way) and holds itself in gear on the highway, the only time it downshifts like I was complaining about, is noticeable inclines which is perfectly acceptable to me.
I think I’ll be okay with my gears now, which makes my wallet happy. Lol
Now the thing I’m noticing is a small roar at low speeds, that goes away when I turn a certain way. (Can’t remember off the top of my head) but sounds like possibly the drivers side front wheel bearing.
Is Moog or Timken an acceptable replacement? Seems like some brands are better than others - depending on the vehicle. Seems like a fairly easy job as well.
Sccritterkiller
SC
I would also check you 4wd actuators...make sure you have vacuum going to your IWE...you have to have vacuum to stay in 4wd...I had a grinding sound coming to a stop...4wd actuator was bad not the wheel bearing..
B
briandye
Can you go into a bit more detail? Im not super familiar with 4WD systems. I am in 2WD mode when this noise is happening, I haven't been in 4WD, or A4WD since before the new tires and lift.
The noise seems to be intermittent, like typically after a long highway drive when I get back in town from work.
vontaehamilton96
Higgston GA
View attachment 24368 Glad to hear you got everything ordered! Sorry, I think ecoboost when I think 3rd gen. I forget that not all of the 3rd gens had it. You should be just fine with the 5.4.
Figured I would toss a picture of mine up on here as well...
This is also with the 3.5" / 2.5"
vontaehamilton96
Higgston GA
This is also with the 3.5" / 2.5"[/QUOTE)
Did you have to change the upper control arm or did the stock one work
