Ford4Life
Newby here. 2008 Expedition Limited, 34,000 miles. Random power loss to radio unit then the light show begins. Panel lights get bright, including control panel lights for a/c, seat temp, etc., warning display lights up bright for tire pressure, parking brake, door ajar. Headlights MAY come on if in shaded garage. Turn indicators do not work while the show is in progress. Then all goes normal and radio comes back on. Event may just include power loss to radio and "Tire Pressure Monitor Fault" and "Door ajar" while Brake and tire pressure warning lights are on. May repeat show several times. Heard it could be water leaking onto the GEM or fuse box from windshield. Hasn't rained in couple of weeks, car is garaged. No discernable pattern to event. Doesn't impact engine operation. Real wierd. Will take to shop next week. Any suggestions on what to look at? I've been told ignition, GEM, fuse box and "bad ground somewhere". Seen symptoms described before on websites but no definitive cure. Seems to be getting worse and I don't want to be left stranded somewhere as a result. HELP and thanks!
