I have read in a few places that the OEM sat radio antenna is compatible with aftermarket sat radio head units but you have to modify the plug for it to work. Specifically, you have to remove some of the plastic around the plug to expose the actual connector.
I removed my stock head unit and noticed that there is only one antenna plug on the back of it which is used for the AM/FM radio. That means that the sat antenna connects to the radio via one of the other harnesses that plugs into the back of the head unit.
So, can anyone tell me where the OEM sat antenna connects to one of the main radio harness plugs? It would be nice to have a little direction before I start "hunting" for it behind the dash.
