Looking to add Surecall Cellular Booster to 2017 EL Limited
Adieu
SoCal
Does anyone have a wiring diagram to get power from the back passenger side? Need 12vDC 10watts on an accessory circuit.
Cigarette lighter socket, but it's always-on-hot and can and will drain your battery
If you want ACC power only with ignition on, tap fuse #33 (10A 12V)
You'll need to tuck the wire under the door sills or up through the A pillar and under the headliner though
PS that's for early 3rd gens, check a diagram for your year
