Losing All Power When Iginition Key Turned
malbertsEL
I have a 2007 Expedition EL. This problem has now happened to me three times recently. I have an "auto start" sequence on my truck. The truck will crank and start when I turn the key to crank and then release.
When I turn the ignition key and engage the cranking of the engine, the truck loses all electrical power. After some trail and error, I discovered that disconnecting and then reconnecting the positive battery cable clears the problem and then I am able to start the truck. Any suggestions? Thanks!
panda24619
San Diego
thats happened to me with my old dvd deck. do you have an after market head unit or anything aftermarket? could be a bad ground somewhere.
2blackfordrides
POULSBO,WA
I agree proly a loose or corroded ground.... Or possibly a bad sensor on the tranny( THATS WHAT I FOUND WITH MINE)... Does the radio work when on accessory?
