FlyBry
For those with a Tune, and monitor or data logging, what max boost PSI are you seeing?
Sorry, but Max Boost is a mostly useless discussion on EcoBoost Motors. These Motors use a Torque Strategy. Basically, even on the same tune, boost can vary greatly based on Octane of fuel, temperature and humidity. The ECM demands a power level basically, and the other systems adjust to try to meet that demand, and obviously back off if knock is detected. So unless the person is in your area, with your tune, under similar load, it is mostly useless discussion.For those with a Tune, and monitor or data logging, what max boost PSI are you seeing?
