IMINYOURCHAIR
Okay, I got everything together tonight after replacing the intake gaskets. First I fought it not idling at all but I had the green and white vac lines reversed. fixed that and she runs like she did when I brought her home. still has a dead miss :/
also, I believe the hose er, metal pipe, that runs from the water pump to the rear of the engine is busted...I should've looked it over while I had the intake off I know but I thought to myself: "It's metal, It shouldn't be leaking" so, knowing I can't remove the intake w/o re replacing the gaskets, I saw a workaround that involves a heater hose, coupling, a few clamps and a 90 deg angle adapter that runs this over the intake. I just need to get the pipe off of the pump housing..
the biggest issue is the miss..I am going to pull the injectors back out and turn it over and see if they are all spraying. Possible that one got gunk in it even though they were clean going in.
