misfire when cold
firefighter407
I got a 99 expedition with the 5.4, My problem is when I start the truck when it's cold I have a misfire until the engine is at normal operating temp.
I changed the plugs ( motorcraft sp-479) and coils ( ebay from uneek) last month. it ran fine till last week.
the check engine light came on and gave a misfie on cyl. #5, I changed the coil and still the same. Any ideas or suggextions?
Thanks
KWT2000
NINE MILE FALLS
pull the plug on #5 and check the gap also check the pigtail to the coil its self... how cold are we talkin, if its freezing crappy gas or a little water could cause a weak injector of act up aswell
F
firefighter407
yup just checked the gap it's about .050, checked all the connectors, changed the plug again, put the old COP, checked all vacuume hoses that I could get at.
Now it even has the miss after the engine has warmed up, at idle it seems fine but if I put it in drive and hit the gas i misses or if n neutral and i give it a quick shot of gas it hesitates rpm comes up and it misses.
Temp out side is average fall weather in canada (12 C today)
any more suggestions? Thanks
KWT2000
NINE MILE FALLS
theres only three things that can cause a missfire on a specific cylinder... no spark, no fuel, no or low compression... it is possibile to have a bad spark plug i see that everynow and again
F
firefighter407
finally figured out the problem, also had misfire on cyl.# 2,3 and 4. but only thing I can't figure out is why the check engine light didn't come on?. and is it ok to mix coils ( I have 3 new ford COP 1 old and 4 from Uneek)?
