Missing vacuum line- someone point me in the right direction, please
UltraClassic
Spring, TX
Howdy- I have been lurking since I bought my 2019 Expy Limited stealth edition about a year ago.
While checking the oil yesterday, I noticed a vacuum check valve clipped above the brake fluid reservoir with an open port on one side. I looked under and over the engine compartment as best I could, but could not find a dangling hose or open port. I don’t believe it’s been gone long, as the open nipple was very clean -maybe pulled the line off traversing high water in the floods we had here a week or so ago.
My nearly 70-year old body isn’t as flexible as it once was, and I could not locate a vacuum diagram here or on other sites that located what need.
The line highlighted in red is the one missing from my Expy..
GixxerJasen
DFW TX
Maybe you'll find what you are looking for in this thread.
UltraClassic
UltraClassic
Spring, TX
Nope, I have already searched and read the forum posts-not concerned with grinding or changing a check valve -just would like to know where the vacuum line that I highlighted in red connects to on the other end. Have also searched online for a vacuum line routing diagram, but haven’t found one that identifies the termination or route of the line I’m missing.
Going_Going_Gone
Phoenix
I assume that the photo in your original post was not your vehicle. Here is where that hose runs to on mine:
Rob6805
You aren't missing anything. Here is a pic I found of a 2019 engine compartment. There is only one vacuum line.Used-2019-Ford-Expedition-MAX-XLT-4X4-59kMSRP.jpg
UltraClassic
UltraClassic
Spring, TX
Thanks! That appears to be the line I am missing… interestingly, the port on the air-intake end was capped off with enough road grime on it to make me think it wasn’t ever connected.
You aren't missing anything. Here is a pic I found of a 2019 engine compartment. There is only one vacuum line.View attachment 81042
UltraClassic
UltraClassic
Spring, TX
Your photo shows the vacuum line I am missing as well
burnsz1984
Nebraska
Bought mine in December, i have the blue check valve but the supply vacuum line was removed and capped off. I remember seeing a video about it but can't find it.
