More wheel wobble
rfaulk93
Mechanicsville
I have a 1998 Eddie Bauer 4x4 5.4L with rear springs (proper suspension :D). Here is the problem. And first off no, its not the wheel balance, ive had them all rebalanced 4 times and just recently broke down and bought four new tires (to no avail, i was pissed). It's not even noticable until i get above sixty. Once i hit sixty, it gets progressively worse as I go faster. I have checked the rear wheel bearings by taking off the disks and trying to move the axle shafts. there is a tiny amount of play but not what i would consider dramatic (maybe 3mm up and down motion). I have not had time to check the fronts, but what I need is a check list, I am a college student and have little time, so when i go to fix this once and for all, i need to attack every variable possible. Could it be bent rims, cv axles out of balance(does feel like it's coming from the front), bad front diff bearings, i mean anything that could cause a vibration, even an unbalanced prop shaft. at this point i will check anything cause i love this truck but i cannot live with that vibration, i know it's doing damage every time i drive it but if i cant find the vibration i will have to sell it. I know i will lose money selling it, but i will lose more money once whatever is vibrating finally breaks.
thanks
panda24619
San Diego
ball joints could be. dose it make the whole truck shake or just the steering wheel?
Capngizmo
Dallas, Tx
Check your drive shafts for dents (out of balance), U Joints, and the bolts holding them on to make sure their not loose...
KWT2000
NINE MILE FALLS
is the vibration in the steering wheel or the seat of your pants?
check the idler arm and pittman arm for sure.'
being that it don't start till 60 or so has me suspecting the rear u joints or tcase
Biged1968
St C. Ohio
to add to what the other guys said, you should check your wheels really close for a slight flat spot , either upward or inward, if you bought it used it may have been curbed good or run into a ditch, also, if there is any play at all in the idler arm on a Expy, it needs replaced.
