motor wont fire.
mustangracer71
florida
Truck stalled out, found out AC compressor seized up, prevented from turning over, installed bypass pulley for now, turns over now but wont fire, fuses good for fuel pump, can hear fuel pump turn on, theft light not on. I'm 100% stumped!!!! PLEASE HELP!!!!!!
Temple, Georgia
Just because you can hear the fuel pump doesn't mean it is getting fuel. Check the basics - air - fuel - spark. One of them is missing from the equation.
Check fuel pressure.
Check the connector on the crank sensor.
Check for spark - keep an old plug and wire for this or use an inductive timing light
Lightnig
Behind you
perfect answer
+ 1
