Mounted up my 35"s
davesexplorer
Berrysburg, PA
Yep got my 35"s mounted up (325/65R18). I trimmed enough so that for normal driving they dont rub at all, turning from lock to lock. Keep in mind I have the daystar coil lift front and rear (2-2.5" of lift).
I will hear the rubber vs plastic battle if I take it off road though... To alleviate this I ordered a 3" body lift for a 04-05 F150 - which I plan to adapt to my expy. Should make for a lot of work...
On to the new pics.
tallsville
LA
have you looked into the rize industries lift for the irs expeditions. it allows you to fit 37's and keep the factory ride.
D
davesexplorer
Berrysburg, PA
Yeah I saw the 8" lift and would LOVE to have it. BUT for the price of that kit, even on sale dirt cheap, I would just rather put more cash down for a mustang convertible.
My total for the daystar lift and the 3" body lift I picked up (for an F150) is roughly $650 including some misc parts I'll probably need when I start on the body lift. 5.5-6" of lift instead of 8" will suit me fine for now saving $3500 over the Rize kit.
tallsville
LA
how hard was it to install the daystars? and how does it ride? i have an 03 4wd. i was thinking of putting 33's trying to get a little clearance but keep it low enough to fit in all the parking garages in LA.
D
davesexplorer
Berrysburg, PA
I had the daystars on and 285/65 18's and was about as high as I could go in the parking garages here and down in baltimore. I still have a little yellow paint on my rear deflector from baltimore actually.
I went to a local shop for their help with the daystars. If you have the tools available to change your shocks you'll be able to do the spacers.
LightningExpo
looks good, quick question for you i want to run a set of 35s on my 2001 eb but they dont make lifts for them.. do you think i would have enough room to stuff them if i crank the torsion keys 3 inches and 3 inch spacers in the rear for the air ride? i want to put a body lift but i think it will mess up the air ride sensor because 4 wheels parts doesnt make one for the air ride. thanks
D
davesexplorer
Berrysburg, PA
I'm not as familiar with the 1st gen expy's running air ride. A lot of people looking to lift them ditch the air ride though!
LightningExpo
can you give me measurements from your hub to the top of your fender? or from ground to top of fender? i need to figure out how much i need to lift it to tuck the 35s
D
davesexplorer
Berrysburg, PA
Lightning,
It's about 22" from the center of my front hub to the top of my fender. +/- .5" or so.
Thanks Texas/Craig!
Had to pick up a new toy since I started playing off road a little bit more and the articulation on these expy's blows pretty bad.
Got my body lift kit in the mail, but that will have to wait till I get about a week off (just in case I run into something).
LightningExpo
thanks, again your truck looks great post some pics of the body lift when you get it all done. im in the process of getting one for mine but i still have some things im trying to figure out on what i want to do to get the lift i need.
rptr00
Las Vegas
Curious...did you ever install the body lift?
Also, whats your backspacing/offset on those wheels?
I just picked up a set of 315/70/17 BFG All terrains and need to get wheels to make them fit. It seems most of the lifted trucks run 4.5 backspacing as stock is about 6 I think.
I have not seen anyone running 35's on a 2WD, so I think I am the first. I know they will fit, my 33's look tiny with the 3" truxxx lift. Its the inside rubbing I want to prevent. With enough backspacing I think they will work.
Anyone out there have any advice?
rptr00
Las Vegas
Well after a long conversation with 4Wheel Parts, I ordered a set of 17x9 with 4.5" backspacing from centerline. They had forged wheels in overstock @ $109 ea.
pics will be posted when its all done.
now, about that body lift...
nvycrmn
Springville, IA
i have an 01 EB and i have a rancho 4" susp lift on mine and i fit 35's with no rubbing except under extreme articulation. i was running 365/65/16 toyo open country tires on 16x10 weld rims.
Gruz7
North Smithfield, RI
On to the new pics.
Just wondering what wheels are those on your red expy??
BIG GREEN FORD
loxahatchee Florida
They do make lifts for 1st gen expeditions
BIG GREEN FORD
loxahatchee Florida
Did you see what year this post was done????....2009 :signs8:
I know you want to get your posts up but this is a little ridiculous:favorites37:
I didn't look at that day that comment was posted, sorry. Because people where still posting here and I got confused.
I don't care about my post # by the way :)
