Musty Oily Smell coming into cabin
1955moose
Looks like your going to crawl under it, and look for oil leaks, particularly 75-90 weight gear oil from one of the differentials, assuming it's four wheel drive. Please post your year, model, 2 or 4 wheel. From where you posted its 2007-13?
1955moose
1955moose
Got it, if you close off all vents, do you still smell it?
stamp11127
Temple, Georgia
Check the cabin air filter and/or replace. Then clean the condensate drain for the a/c. Spray a large amount of Simple Green in the vents including defrost to clean out the plenum box. You may have to do this a few times.
rjdelp7
2000 XLT
NY
Check your CV shafts. The rubber boots are packed with grease. A small rip will spray, stinky smelling grease on undercarriage or back of wheel. Over time, the lack of grease will cause it to fail.
Dustin Gebhardt
Tulsa, OK
It could also be a heater core leak. Is the problem better or worse when you set the climate control to hot or cold? If it's worse while set to a higher temperature, your heater core could be leaking. Many people categorize coolant smelling like sweet, musty, or greasy/oily.
bobmbx
To me, it smells like brown sugar and maple oatmeal.
chart75
Denver
Let me know what you find. My wife's 07 Limited 4WD w/202K started doing the same thing last week under all conditions.
