Don't do that. The noise was on the right side, right? You swapped the bearing didn't chsnge? If your noise is definitely on the passenger side, did you make sure the tire direction is correct? I've seen people have them backwards.Check that next. Jack the front up, run it, turn wheels, engage/unengage 4 wheel drive. Remove right front axle temporarily. See if noise changes. If you've elimanated the 4 wheel drive vacuum solenoids, and vacuum going to them, and your sure the tires/ wheels/ brakes are all sound, your looking at front differential.Thats the logical next step. Run a obd diagnostic to be sure.
I'll check the tire direction. Maybe somehow they're on the wrong side I'll swap those around see what that does.
I'm certain now that the front axels are not engaging or turning. The front tires are moving free of everything
