Wheel bearings ?????
tilliepeople
Madison
When turning slow the left front tire squeals and sounds like the tires dragging.
Did the standard shake rattle and roll checks but all felt tight .
I wasn't sure what the problem was until I had someone back up slow and turn the wheel slightly .
It looks like the wheel is about to fall off (leans way over).
I am now "assuming " the wheel bearings are shot.
Already changed tie rod ends and sway bar links which did show bad
Anything else that might cause that.
Thank you
Bill
2004 Lincoln Navigator
T
tilliepeople
Madison
4WD
yes I pulled the wheels off
Even with big pipe nothing seemed to be loose
BUT
The upper bal joint moves a little and the boot is pretty much pulled off
I am going to replace both upper control arms and see what happens
Just got to wait for parts now
Turns out the shocks will be the hard part .One has a rounded off nut I can not get off
Matthew Jenkins
Colts Neck, NJ
Wheel bearings are easy to check. Lift the truck. Put your hands at 3 and 9 o'clock. Push at 3 pull at 9 and alternate. Any opposite side will do. If the tire moves at all the bearing is going.
