Need Help!! Some kind of electrcal problem
bigmike11912
California
Hi guys this is my first post and I have read alot of your guys advice for other problems I have had and they worked out. I have a 97 expedition EB 5.4
I was driving down the freeway the little battery light came on and about a minute later all the guages on the dash just dropped as if the engine was not on. I was able to drive about 5 more miles trying to get off of the freeway and then it died.
A tow truck hooked up jumper cables and it started but soon as the cables got disconnected it slowly started to die out again.
Once I was towed to autozone I had the battery cherged and the alternator tested. The alternator failed so I replaced it. They said the battery was taking a charge but then later said that it was no good so I replaced that. After putting in the new alternator and new battery she started right up but the battery light stayed on.
The next day I started it up and it was fine. I drove about 10 miles and the guages dropped again and it died.
I took the alternator out and returned it for a new one and cleaned the battery cables. I havent had a chance to start it yet. But has anyone else had these issues and if so where can I start to try to resolve it. Thank you in advance for any advice you can give.
Stranded Mike
stamp11127
Temple, Georgia
I didn't feel like typing a book so check this link out:
HowStuffWorks "How Alternators Work"
Once you have read and understand why your alternator idiot light comes on we can assist you with troubleshooting the system. If you don't have one I would suggest buying a decent digital volt meter (DVM). Search around, there are plenty of good ones in the $50-80 dollar range. This should be a tool in every tool box
Check this guy out for beginner dvm's. He gets colorful when he starts ranting about design quality.
http://www.youtube.com/watch?v=gh1n_ELmpFI
nsperf
Akron Ohio
I would have to check the wiring guide.
First follow the post above. A meter makes it alot easier. I prefer to get one with volts and ohms. This can be used to test grounds, wires, switches, fuses, sensors so it is a useful investment.
You will have to check to make sure that all connections to the alt are good tight and corrosion free. Ensure you have a good ground. Check and verify any fusible links, bad alt or battery has been known to burn them
