No. 4 cylinder
Willshooter3
Bishop Texas
Having a bit of problem, had a bunch of engine codes on an 06 XLT. Got everything cleared, down to a 0304, replaced the coil pack... still have 0304 code, still have a miss, truck runs like crap-misses; and the engine light is flashing.
Habbibie
Is it Christmas yet?
Chicago
Change the spark plug!
good luck though, that's the hardest plug to reach.
Bedrck47
Elizebethtown, PA
You only mention replacing the coil pack.
Did you replace the plug and boot?
Did you check the wiring connector and check the wiring back to the PCM?
Bedrck47
Elizebethtown, PA
Nothing like only doing job half way OR HALF A$$ED Had that problem once in the past turned out to be a pin hole burn in the boot
BOOT? The rubber part that contains the spring wire that connects the coil to the spark plug
Bedrck47
Elizebethtown, PA
Well sometimes people just buy a coil and some coils come with the boot and some don't
But I have a hard time trying to figure out why someone that is getting a misfire code would only change the coil and not the spark plug.
How many miles on the expy?
And when was the last time ALL the plugs were changed??
Willshooter3
Willshooter3
Bishop Texas
250K... last time they were changed was 100K... dealer serviced it... Yeah. I dunno. Maybe I was in a hurry. A big hurry and trying to get it fixed in a hurry.
Bedrck47
Elizebethtown, PA
Sounds like its long past the time for ALL the plugs to be changed 100k on the firs set yet 150k on the second set and haven't been changed yet I can imagine what the gap on the plugs looks like
1969 Bulldog
Kansas City, MO
Found a qualified mechanic on craigslist out on his own. Changed all the plugs & coils for $125 labor in a surprisingly short amount of time. Definitely worth it to me.
