no 4x4
mberg
rochester mn
I got stuck in a flat parking lot the other night it had just snowed, so I put it in 4x4 hi and it was still in 2x4 but the light lit up indicating that it was in 4x4. Hoping someone could shed some light
thanks
JUST4FUN
Admin
Moderator Administrator
Il
need to know the year
dubedition2003
North Shore, MA.
Try putting your ride in (N) then twist the 4x4 switch on. If this doesn't work check the fuses or try banging on the transfer case.
JUST4FUN
Admin
Il
the older expys used vacuume to activate the front wheels
M
mberg
rochester mn
Ive tried to bang on the transfer case and Im still getting no luck. The fuse is fine and the light indicates that it is working but I guess im just wondering how the whole four wheel drive line works my truck is a 1997
thanks for the input
lakmflx
P.C.B
:confused:
What exactly are you wanting to do ? or whats the problem...
green03
College Station, TX
put the truck in 4x4 and drive down the driveway. Then jack up a front wheel with the truck running and see if you can turn it freely. If it turns freely then see if it is spinning the shaft from the front differential to the wheel. Do the same for the other side. If the shafts are engaged to the wheels it is a problem in the transfer case. If the wheels and shafts are disconnected then the problem is in the front hub assemblies. I think your's are vacuum operated so it could be a vacuum line with a hole in it or disconnected......
Matt R
lakmflx
P.C.B
I originally thought vacuum but wouldnt his 4x4 indicator tell him its not working if there was a leak?
green03
College Station, TX
I don't think that the indicator tells you anything but what the position of the engagement fork is doing in the transfer case...... I put money on the hubs not getting the vacuum signal or lack thereof. Mine disengage when there is vacuum so that in a no vacuum situation (wot) the hubs would remained locked. Some trucks are reversed and I don't know which ones they are.......
Matt R
