rob194
Hello everyone, I am having problems on our 2018 XLT. We have the high beams but no low beams. I checked through the fuse panel and did not see a dedicated fuse. Has anyone had similar problem?
Thanks.
Thanks.
Could be the Multifunction switch on the column.
low beams and high beams may have separate circuits. Could be a bad relay, loose wire, harness plug or ground.
Did you check the owner's manual for fuse definitions for low and high beams or relays?
I am not the OP.I think the OP has a 2020 Platinum, HD Tow, Star White Tri-Coat <----
AHH, well according to the schematics, the fuses are located in the battery junction box. On my 2019, it is located near the battery.I am not the OP.
From the first post in this thread:I think the OP has a 2020 Platinum, HD Tow, Star White Tri-Coat <----
