OEM Raptor Wheels and Tires
Mack207
Wilmington, NC
Reviving this thread. Bought a ‘21 Stealth earlier this year and didn’t care for the 22’s. Just found some local 100-mile beadlocks for sale on CL. Had to pull the front fender liners forward by removing the three screws and making new holes in the liners. The driver running board was too close for comfort, so I undid the four bolts holding them to the actuators and slid them back 1/2”. Looks and rides much better. Curious what an alignment will do since the passenger side seemed to fit better. Stock height with CCD.
Bigmaccray009
2021 Max Limited, stock suspension on 2024 raptor rims and Toyo Open Country AT3s 285/75/17 C rated. I have 5100s and will be throwing those on at some point. No rub and feels like riding on pillows compared to the 22s. The 2024 Raptor center caps are a bit thicker so, I’d need to cut a 1/2 inch off the half shafts. Good times. IMG_6685.jpegIMG_6687.jpeg
VBreithaupt
Looks good! If I was on more dirt roads and trails I would consider it. Mine sees to much pavement.
Calidad
California
The amount of snow and ice buildup in the wheel wells has been interesting at times with stock setup. I’m guessing no ice or snow in your region? Not sure I could go bigger without serious winter issues.
Beachbumberry
Waco
Holy zombie thread Batman!
I've lurked on this forum for a while, I bought my 2019 Max FX4 2 years ago and a set of raptor take offs that needed tires a week after. Well now I needed tires, so it was time.
IMG_4717.JPGI did see the common answer for the center caps is to either cut the stub axle off or not run center caps. I didn't want to do either, so I designed a 3d printable spacer to install them. Here is the link to the printable
Thingiverse: Raptor Rim Centercap Spacer
Langer
Chicago
I took the plunge. Found 2023 Raptor takeoffs with KO2s, put bilstein 5100s all around (2020 f-150 4x4 on the front, at second lowest ring gave a full three inches of lift. I had only seen people with lowest ring claiming 2-2.5 inches, but none I’ve seen higher. Expedition rears at highest setting). I got the rough country upper control arms for 2.5-3.5 lift. 1.5 inch wheel spacers on rear so no cutting the axle to fit the wheels. No rubbing anywhere. Pretty happy with it, just about totally level at ~38.5 inches from ground to fender at all wheels.IMG_3513.jpeg
Expensedition
Newport, RI
Love the look of the bigger wheels.
The way it should be.
llldatlll
