Oil maintenance question
deweysmith
Montreal, QC
Also a plug for Blackstone Labs, but if you're really curious about how your oil is doing, order a kit. They're free to order, free to send back. $28 once the sample arrives at their lab and they've processed it.
Boose
2017 Platinum EL
NJ
The bottom line is that you will NEVER ruin a motor by changing the oil more frequently... you all do as you like as the inverse of my statement is not also true. With the fuel dilution present in these ecoboost motors, I will not go over 5k.
jeff kushner
North of Annapolis
With modern engines, the oil itself is rarely an issue anymore( the chem pkgs are so good)...the problems we see in modern high performance engines is that with the much closer tolerances allowed by much closer engine temperature control, smaller foreign particles (dirt) are embedding themselves into the faces of insert bearings, cyl walls, cams and staying there causing premature galling and ultimate failure.
A good way to remove these before they become embedded is to change the oil/filter often......but as I've always championed....it's your truck, do as you wish!
jeff
Dorzak
California
I'm still working with the high authority to come up with a fit punishment for this.... we are considering at the least hefty fines and community service, may be some time behind bars.
Flog him, Flog him, flog him.
08T1
sierravista, az
Game of Thrones comes to mind.....
“Shame....shame...shame...!!”
Penance!!!!
Lol
Muddy Bean
I was perfectly comfortable going 20,000 miles between changes on Mobil 1 Extended Performance and it’s matching oil filter. But I switched to a much larger oil filter, and I always checked the oil. During an oil change the oil was still always dark honey even after 300,000 miles on my Land Cruiser. But the oil in my ecoboost is black and nasty after 5,000 miles so I’m changing it often.
08T1
sierravista, az
A larger oil filter??
I have been trying to locate a higher capacity filter for the Expy.
How did you locate one for your old ride?
Muddy Bean
Many times once you find your oil filter, you can compare it to others for thread/opening size. If that part is the same and the oil filter is just taller, you can use it if you can fit it in your space. Like this:
More media, more filtration capability before bypass mode.
bobmbx
Not always true. Some oil filters have check valves, especially those on cars with turbos.
