Oil maintenance question
Changingtime
Columbus
2016 expedition el ecoboost. Is there a place/diagram/engineering document that shows the factors that are taken into account in the oil change percentage.
Ie, time between changes (days), miles driven, etc
I have 2 oil changes with approximately 14000 miles. The first change had a lot of percentage left around 6k miles, the last time around 14k it jumped to 5percent (but it had been one year between those miles).
Dealer stated (change every 3000 or so, bc they say we live in extreme environment / I disagreed with them, I live in Columbus Ohio.
Habbibie
Is it Christmas yet?
Chicago
12,000 miles intervals here, this is my set up below, I use the same oil to top off any burn off once a month
08T1
sierravista, az
Oil analysis is the best way to know where the oil life is. So many different brand oils, viscosity and filter....drive styles and weather....
In a way pick an oil and filter you like. Do some research and make yourself warm and fuzzy with your choice.
CJ
M1 Extended performance is a good oil. MC oil filters are a great choice too. JMHO
jeff kushner
North of Annapolis
Dealer is LYING to you....as you've surmised, Columbus Ohio, unless it has been drastically affected by the global cooling temperatures and maybe some high winds added in, is not an extreme environment!
FWIW......Be leary of going long distances between changes.....as the filter will automatically go into "bypass mode" which will not only recirculate dirty oil without it being filtered at all but will in many cases, allow previously filtered dirt to reenter the oil system. With these "half size filters", I try to stay under 5K....but you do what you feel it right after gathering the info.
jeff
iimagine
2016 EL XLT
I'd say 5,000 miles is a safe interval. That's why most members on here do.
On my 2016 EL XLT, I go 5-7,500 depending on what the computer "suggests". We're not in an extreme service area, but do travel some dusty, back-woods, dirt roads and I take that into consideration. I use Motorcraft 5w-30 Synthetic Blend Oil with a Motorcraft FL-500-S filter. I've used Motorcraft oil and filters since I was a pup and old habits die hard.
deweysmith
Montreal, QC
You might have missed my 10,000 mile oil analysis thread where everyone told me I was clearly an idiot for gambling with my engine's life and I should be subject to capital punishment, but you're fine.
The computer takes into account ambient temperature, time spent at operating temperature, engine speed, mileage, actual time passed, and probably more. Unless you're Scotty Kilmer, it's plenty trustworthy, and if you're doing them at the dealer, Ford has records they were done right and on-time, so if something happens and you're under warranty, you're blameless.
Dealer is telling you 3,000 because they want your dollars. Even my 2001 Oldsmobile says 5,000 is fine, the computer usually ends up telling me to do it around 6,500 though.
Flexpedition
midwest
According to intellicast Columbus record low is -22°F and record high of 106°F. Suppose everyone has their own opinion of what constitutes "extreme".
I'd suspect there is a complicated algorithm that factors, among other things, calendar time since last reset, idle time, each run cycle duration, temperatures (oil and non-oil) before and during each run cycle, load percentages on each cycle, observed oil PSI ranges, with mileage somehow calculated into it all.
Probably wouldn't make sense to most outside of the engineering world.
I'm still working with the high authority to come up with a fit punishment for this.... we are considering at the least hefty fines and community service, may be some time behind bars.
deweysmith
Montreal, QC
Also a plug for Blackstone Labs, but if you're really curious about how your oil is doing, order a kit. They're free to order, free to send back. $28 once the sample arrives at their lab and they've processed it.
Boose
2017 Platinum EL
NJ
The bottom line is that you will NEVER ruin a motor by changing the oil more frequently... you all do as you like as the inverse of my statement is not also true. With the fuel dilution present in these ecoboost motors, I will not go over 5k.
jeff kushner
North of Annapolis
With modern engines, the oil itself is rarely an issue anymore( the chem pkgs are so good)...the problems we see in modern high performance engines is that with the much closer tolerances allowed by much closer engine temperature control, smaller foreign particles (dirt) are embedding themselves into the faces of insert bearings, cyl walls, cams and staying there causing premature galling and ultimate failure.
A good way to remove these before they become embedded is to change the oil/filter often......but as I've always championed....it's your truck, do as you wish!
jeff
Dorzak
California
Flog him, Flog him, flog him.
08T1
sierravista, az
Game of Thrones comes to mind.....
“Shame....shame...shame...!!”
Penance!!!!
Lol
Muddy Bean
I was perfectly comfortable going 20,000 miles between changes on Mobil 1 Extended Performance and it’s matching oil filter. But I switched to a much larger oil filter, and I always checked the oil. During an oil change the oil was still always dark honey even after 300,000 miles on my Land Cruiser. But the oil in my ecoboost is black and nasty after 5,000 miles so I’m changing it often.
08T1
sierravista, az
A larger oil filter??
I have been trying to locate a higher capacity filter for the Expy.
How did you locate one for your old ride?
Muddy Bean
Many times once you find your oil filter, you can compare it to others for thread/opening size. If that part is the same and the oil filter is just taller, you can use it if you can fit it in your space. Like this:
More media, more filtration capability before bypass mode.
bobmbx
Not always true. Some oil filters have check valves, especially those on cars with turbos.
