Nasanieru
Hey ladies and gentlemen,
Ok, I have new info about a suspension issue I have been fighting with on my "99 expy EB 5.4L, No air ride, Swapped over to coil/over Shocks."
I have changed and checked the next set of things. " Both of the front sway bar links, checked rear sway bar and is connected correctly, body mounts are still good." I also wanted to mention that I have not had the tires alligned on the truck for quite some time, Actually since I have owned the vehicle. lol.
I have taken the liberty to make some measurements of the lean from 3 different places to see if it helps identify where and from what my lean is coming from.
Wheel Well Gap: The Measurement was from the center of the hub to the bottom of the wheel well lip.
DF - 20.25"
PF - 20.75"
DR - 21.25"
PR - 20.50"
Shock and Coil sizes: Actual measurement of the size of the shocks/coils on the vehicle. Again they are converted from air to coil over all 4 tires
DF - 17"
PF - 17"
DR - 15"
PR - 14.75"
Torsion Bar Bolt Height: this is the measurement from the top of the bolt to the small plate on the inside.
DS - 1"
PS - 1-3/32"
There is all over the info that I can give...I dont know what to do, and am holding off getting the truck alligned because anything I mite need to do could require me to get the tires adjusted again.
Thanks guys, any help would be awesomely helpfull
Nathan
DF - 20.25"
PF - 20.75"
DR - 21.25"
PR - 20.50"
DF - 17"
PF - 17"
DR - 15"
PR - 14.75"
DS - 1"
PS - 1-3/32"
Nathan
