OK- what sound is THIS? TDI mod?
lv2drive
lv2drive
PA, USA
so she’s going under the knife -
first up, phaser surgery.
dealer is solid, best local option, engine specialist is very decorated with this procedure - that said...
Q - for those of you who have done this already - or are more familiar with the fine points - what lessons have you learned post op, or particular details should i insist on with them (aside from the standard “replace all affected seals/gaskets, timing chain”)
anything else additional or extra i should do or push / beg for while he’s up in there?
any other tsb i should throw at them that could involve crossover labor?
TIA
PS they’re also replacing the front shocks & covering it under extended.... wondering if i bite the bullet & just buy front 5100’s instead so i don’t have to deal with it again? pretty sure i can get them to install them without charging labor -
DWs-TTEB
Evans, GA
Ask for an oil & coolant/antifreeze change. Metal and stuff will get into your oil & coolant when they are doing the phasers
DWs-TTEB
Evans, GA
I ordered bilstein 5100 front struts on Jan 5, 2021. Still waiting for them. Got the rear shocks 2 weeks ago. So if you don’t mind waiting 3-4 months for the front struts do it.
lv2drive
lv2drive
PA, USA
got her back today.
purrs like a sleeping lion. night & day difference. pulls harder & more responsive, which is probably a combo of the EB getting proper timing again & throttle reset my guess.
took about a week.
they replaced the water pump as well while they were in there, as a precaution - i flagged it over & over & reminded them that it’s covered under warranty if it fails so might as well do it now if you can see what you need to see to make that happen. & they did.
replaced the front two shocks under warranty, will replace them next go round (in god knows how few miles from now !)
NOTE: for those who are going to do the phaser.... when resetting the body down once complete, the tech screwed up & didn’t notice that he had pushed the gas nozzle down out of place. went to fill it up, & the 60iq gas attendant proceeded to fill up my left rear wheel with premium (because there was no downspout receiver, just a hole.) dealer promptly put me in a Yukon (yuck-on!) which gave me a great comparison that lasted all of a few hours before i insisted on a different vehicle. yes it was that bad, IMO. i would rather have a tempermental expy over one of those any day.
anyhow, my love hate relationship with this vehicle continues. what was that phrase... buy a ferrari & be prepared for the headaches? well this is my ferrari then, i’ll take it... the good is clearly worth the bad.
nameisbry
