Well, I shut down the air system, removed the ride height sensor, cleaned the connectors and the sensor moves freely. I will activate the system and try to see if I can move the sensor manually. Do I disconnect the lower mount and extend and retract the arm? And wow! nice ride Tony! someday I'll be able to afford that stuff........(I'm married, so I have no more money, no pride and I'm tired all the time....) lol! Do I need the truck running with the air suspension in the on position, then crawl under, remove the bottom clip of the sensor from the mount, then push the rod up and down slowly to see if it has an effect? If I do this and get nothing from the system, where do I check next? Thanks!
