You can install the overhead entertainment center yourself, its take about 4 hours. The kit I got is from Ford with the "The Ford Motor Company" logo on it, it come with detail instruction on how to install it along with pictures. The front bracket screws into a plastic subframe under the roof lining and rear bracket attaches to roof support beam which support the weight of the unit, You line up the template and cut the hole., then the rest is clockwork including where to run the cable and where to splice to power the unit. The kit come with wireless headphone and FM modulater. It is very professional.
