Overheating ecoboost
C
coolzzy
Idaho
I firmly believe it is a computer issue and not actually overheating. Each time I've observed it, I was watching the engine temp guage and as soo as I let up on the gas the temp dropped very quickly, like 3 to 4 seconds returned to normal. I've found if I keep my speed under 60 on the steep pulls and no higher than 4th gear, I've had no issues. Any faster or higher gear and it trips the warning. The warning I get doesn't say to stop it just says reduce speed, which is why I think it's a programming safety. Never a lack of power though, still pulls like a train.
jak1221
Arizona
I have same overheating problems with steep grade towing at ambient temperature above 90F. I live in Arizona and all the Gen2 Ecoboost whether F150 or Expedition have same overheating problems. From all those I have talked with the fix is a combination of larger intercooler, added transmission cooler while keeping stock heat exchanger, and larger radiator. No, one things fixed the whole cooling system is undersized when towing steep grades at high ambient temperature. I agree with others that doing the fixes on a new vehicle that was miss engineered is crazy.
JasonH
Houston, TX
I suspect this issue may be related to too much boost and not enough gear. My travel trailer is 7K, but I have not towed over large grades for a long period of time, so I have not personally experienced this issue. I've noticed that my 2017 EL will boost instead of downshifting. With the turbos, these engines can generate a lot of power at low RPM. Perhaps the water pump is not being run hard enough at low RPM to circulate the coolant adequately. In addition, running the turbos hard for a long period of time will likely cause heat soak, hence the intercooler upgrade potentially helping with the issue. I suggest running the torque app and checking the inlet air temperature while towing on grades to see if temperature increases over time.
What are the EcoBoosts running for a cooling fan? Are they the twin electric fans like the 2010-14 5.4 V8s? It seems the big electric clutch driven fan on the 07-09 grabs more air when the ECM commands clutch lockup. My 2007 Expedition EL has the 5.4 Triton/ 6R75 with HD Towing Package and I’ve never had high temps towing uphill (granted my boat and trailer are about 4,000 pounds and aerodynamic so the truck isn’t taxed) but when the ECM commands electric clutch lockup the fan cools everything down fast. The later twin electric fans on the 5.4 seem to cool better at low speed but it seems the earlier electric clutch cools better under way.
99WhiteC5Coupe
Some of the posters talk of the EcoBoost overheating while towing, but do not state if their vehicle has the HD tow package (or the base tow package such as on the XLT models).
My 2015 Expedition Limited 4x4 came standard with the factory HD tow package, although I do not tow with it.
For those of you with the overheating issue - do you have the factory HD tow package (with no aftermarket tuning)?
C
coolzzy
Idaho
I have the HD tow package on my 17 ecoboost, 3.73 gears, bigger radiator and transmission cooler. More than likely this "nanny" warning is a result of too much boost as speculated earlier. The F150s with max tow package experience the same issue. Drop a gear or two to reduce boost and you'll be fine. If you get a 5 star tow haul tune, it actually takes this into account and will downshift sooner and use the motor more to keep the turbos cool unless you are really stepping on it while towing.
3tonsoffun
Sounds like you need a 170 tstat upgrade. I never see over 190 coolant temps on my 2016 EL HD tow. It definitely keeps the engine cooler. I run a 5 star 93 perf (daily) and have a 93 perf tow also
reidar
Sandy UT
I have been experiencing the same overheating issue with my 2016 EL Limited with the HD Tow (larger transmission cooler and 3.73 rears). Mine is not chipped. Standard size tires. My transmission never goes over 210. I watch temps with my torque pro app, in conjunction with the gauges (or lack there of.)
We were coming back from Northern Utah the other day with my family (6 of us and a dog) and my travel trailer which weighs slightly over 5k loaded. We went over Sardine canyon from Logan and the engine temps started creeping up to 244. It was 85 degrees. When going downhill it did cool off quite quickly, down to 230 then 220. When I got back down to the valley (which is pretty flat), it was getting into the 90's outside and my temp still was in the 230's. Still too hot if you ask me. I was not pushing it hard. On the steep hills I kept it at 55. In the valley I was at 70-75... pretty much the speed limit. Like others have said, this engine pulls like a train... but the temperature spikes scare me a bit.
Last year I got the dashboard warning when I was going up Parleys canyon... which is fairly steep... but I wasn't driving it crazy then either.
Like what was mentioned before the computer maybe the cause of this. These 3.5's have amazing torque at lower RPM's, I'm thinking to keep the transmission from heating up it is using the turbos to keep it in a higher gear... but that ends up causing the engine to get too hot. I don't know.... I do love this vehicle. It out pulls any day of the week my old 2004 Expedition with the 5.4.
Rod
JasonH
Houston, TX
Rod
What gear were you in when you saw the temperature spike? Were you running 91/93 octane?
reidar
Sandy UT
I was running 91 octane and I want to say 4th gear... but I'm not sure. I kept it under 3000 rpm.
Rod
LovinPSDs
Houston
Rod
Seems some people are having more luck with bumping the RPM up to increase waterflow... additionally, I think I'd be looking to drop in a 180 or 170 T-stat if you tow a lot. (especially in large grade areas)
While in theory this doesn't fix a "max temp" issue I believe there are aftermarket T-stats with a larger overall opening (allowing more flow) and it gives you a lower starting point/baseline when there is a potential to heat soak the cooling system.
I'm not 100% sure on this, but I think on the 15-17s you'll also need to reprogram to adjust the fan engagement temps.
reidar
Sandy UT
Interesting... Next time I'm towing up a steep grade I'll drop a gear and keep the rpms in the 3-5k and see what happens. Now I'm curious...
Thanks all!
Rod
LovinPSDs
Houston
Thanks all!
Rod
Again, this is just from a ton of reading I've done on here and the F150 pages (don't own an EB yet) but "lugging" the engine seems to create the issue more frequently. Coolant flow is relatively low, while boost is high and turbos are running HOT. Bumping RPM increases flow, should drop the boost some and in theory help SOME in cooling everything down... let us know what you find out.
reidar
Sandy UT
Will do. I'll take a screenshot of my TorquePro too when It's spiking. With inlet temperature and what gear I'm in.
Thanks Ian.
Rod
mactlc
Colorado
My Ecoboost overheats too! I exhibit the same behavior as coolzzy on long steep grades with my foot in the gas.
I just took my 2017 Limited Expedition EL on the first big test up the IKE Guantlet. I drove from Frederick CO, through Denver then up over I-70, then down to Silverthorne. I had my 4 kids in the expedition, dog, and the trailer had a moderate amount of camping gear. I didn't weigh it this time but it was likely around 6500lbs in the trailer + our passengers/dog (750lbs).
The only time I experienced overheating was coming from the Denver side which is backwards from what you'd see in the youtube/IKE tests that TFLTruck performs. From the Denver side you end up climbing at 6-7% grades, you have some steep down hill runs, then some flat or gradual runs, and some really steep 6-7% runs. Overall though, coming from Denver side heading west, you experience a lot longer pulls. It's a harder test than what those youtube guys do...at least for engine temps.
I received the overheating/dash warning for the engine temperature when I had my foot about half way in to the throttle, the engine seemed to be handling the load just fine, it just must not have adequate cooling to handle the sustained grade. I will admit though, I was probably doing 65mph or a hair more when the light came on, and I had been going up a very long grade not giving the engine much break at all, once I backed off the throttle a bit, dropped it to about 55mph, it started to cool down. The gauge showed the temp around 3/4 of the way up, not in the red yet, once letting off the gas, it began to drop slowly. It took about 30 seconds to a minute or so come back down to reasonable mid range on the gauge. Once back to normal, I didn't have the issue again and just kept it around 60-65mph. If I hit a really steep long grade, I just watch the engine temp gauge, if it started to creep up, I'd slow down to 55 or 60 and it seemed to hold there.
On a side note, the ecoboost pulled the IKE gauntlet very easily compared to my old 8.1L vortec. It also pulled much better than the 2017 Sequoia I had....gotta love those turbos at high elevation.
I was thinking I could probably add a larger radiator, or maybe a lower temp thermostat, but honestly I probably shouldn't be doing more than 60mph up that pass anyway, so I'll just go a hair slower in a few spots to keep the temp down. I don't ever see much worse temperatures or grades than I do here in Colorado.
The only area that it didn't perform well was with the rear end wiggle. Compared to my old 3/4 ton Yukon it wiggles a lot with wind/semis, but it still wiggles a lot less than my Sequoia did. It was manageable, just not great with the wiggle. I have my WDH and 4 point anti sway setup pretty well, lots of end bar weight for the sway control, and I increased my rear tire pressure to almost max.
The same thing happened to me going from Denver to Breckenridge, however, I had made that climb many times before without issues. I came across a post on a different forum and they said a dirty air filter or non OEM filter can cause the over heat under load and quickly recover after boost stops. I purchased a Motorcraft air filter and like magic the overheating went away. The other forum also said stock thermostat is best but the aftermarket one I installed seams to work just fine. Also suggest a new radiator cap ever 5 years, I still have my original on my 2015 Expedition EL with HD tow (Just adding to this old thread Incase someone else has this issue).
