Park Assist Camera Issue 2016 Limited
STINNETT
Memphis, TN
Anyone see this with their factory park assist camera? It will glitch for a few seconds then give an error of camera unavailable contact dealership.
Snidley53
Indiana
I had the issue without the camera is unavailable message and mine went away on its own. It will probably return then I will need to look at the wires and connectors as some others on this forum have reported that is what they had to do or replace the camera. If you do replace the camera I believe it will need to be programmed to work though I may have not remembered that correctly.
STINNETT
STINNETT
Memphis, TN
It worked correctly when I got in it after work. I guess I will keep an eye on it and check the harness connections. Thanks for the info.
