Fordhearter
I have a 99 EB 4x4 that I am about to rip the rear brakes apart for the like the 10th time. For some reason my rear brakes kept getting hot and dragging. I started with the parking brake and gave it a quick clean and grease job and adjustment. Seemed to work for 1-2 weeks. Happened again so I adjusted them so they were a little bit loose. Again worked for like a week or so and happened again. Then I thought the calipers were somewhat hard to push the piston in, (just replaced front caliper) so I replaced both rear calipers which fixed the problem for about 2-3 weeks. Mind you while I had everything apart this last time I cleaned all the rust from the parking brake scissors that the e-brake cable pulls on. Cleaned and greased adjuster screws and set them to as lose as I could. Everything was awesome until today I could feel the truck dragging again and when I got home the drum part of the disc/rotor was super hot when I touched it. I literally don’t know what to do, I’ve never had this many problems with rear brakes/ parking brakes. Anyone got any ideas?
Also side note isn’t there supposed to be a small metal bracket on the adjustment screw that holds it(clicks when you adjust them)? I didn’t have any and my Haynes manual doesn’t show one in the picture.
