Passender window and door lock control switch bulbs burnt out
Rider
Grand Rapids, MI
Can these be changed or do you need to replace the entire switch for each control. 2005 Eddie Bauer. The entire passenger door lock switch is burnt out and just the down arrow on the window switch is out.
ELVATO
Orlando, FL
They are LEDs, so it it very unlikely they are burnt out. If it's like most everyone's case, it's just bad circuit design. If you take the switch apart, and clean everything, it might work again, though it usually seem to be a bad solder joint/contact.
I have a video showing how to take it apart, and showing how pushing on the circuit board makes the LEDs turn on.
