getdealtwith
There probably is a thread somewhere covering this question for 2nd gen Expys already. If so, please point me in the right direction as I haven't been able to find it yet.
If not, here's my question: ever since installing a new battery and replacing the corroded terminal connector, I've had the PATS on my car go off. It happens every time I unhook the battery and occasionally after unlocking the doors. I'm only using the OEM key. After unhooking the battery, I have to go through the procedure of putting the key into the door lock, turning and leaving it for 50+ seconds to shut up the PATS. In case of the random set-offs, putting it into the ignition has sufficed in a couple of cases.
What is the issue here and how do I fix it? Affix the OEM key near the ignition lock and use a spare or replace a module?
This isn't a huge issue for me but I'm trying to avoid my wife running into this on trips with our baby. Thx
