Photo of brake vacuum line routing to intake manifold
T100T
Car is a 2008 5.4 Expedition, am looking for help re the routing of vacuum line that runs between the base, at the rear, of the inlet manifold and the brake booster. Specifically at the back of the driver's side valve cover does the vacuum line pass between the harness and the cover/rear of cylinder block or does the vacuum line pass over the harness? A photo of that area would be appreciated.
A couple of photo's to show where I'm talking about.
Thanks,
Peter
ScottyHill
Manchester, UK
I had trouble figuring out the routing too until I spotted the booster check valve pointing upward toward the intake. That vacuum line snakes underneath a bit before connecting into the fitting right behind the throttle body. I had to move the wiring harness a little to see it clearly. Took a pic for reference and saved it on my Nixplay so I don’t lose it again down the road.
