Photos of Trailer(s) that you tow with your Expedition
rdlangston13
Katy, TX
What Ford engine do they use? Trying to think what engine Ford makes that would work in marine application, 6.2L V8 from the Super Duty?
It’s the 6.2 from the F150 raptors. Similar to the super duty 6.2 with different cams from what I understand.
Great engine, what’s the redline on that in a boat? In the trucks they’ll shift right at 6 grand.
johnboneske
Ohio
its more than just different cams...Mercruiser gets the engine and takes all the internals out, and puts in all forged stuff, better balancing, etc... Your cruising RPM is probably around 4800 to 5000 RPM and max R's when running full throttle is probably around 6500, and you can run that for an extended period of time. There isn't a "stock" engine that can take that from the factory. Marine engines may be the same block as a car engine, but the internals aren't the same. Just letting you know.
I wasn't a huge fan of mercury on the sterndrive end, good inboards and outboards though. I liked the OMC Cobra units.....they finally made a good product and went out of business shortly after. Was a nice durable design and changing the impeller was the easiest I’ve ever done....ah well. Quite beefier than the comparable Mercruiser Alpha One. I still have two Cobra drives sitting on stands in storage.
Many of those Cobra sterndrives were also behind a Ford engine. OMC used Fords 5.0, 5.8, and 7.5L 460 engines behind their products. In fact Ford and the marine industry were defunked for years after the demise of OMC. It seems they’ve just got back in the game now.
rdlangston13
Katy, TX
My engines max rpm is 5300 and the manual states not to run over 4000 for an extended period of time. We usually cruise at about 3700 rpm.
johnboneske
Ohio
there is NOTHING better than an OMC cobra drive!!
Our old boat had a 350ci with a OMC drive... Four Winds commonly used Ford engines too, along with Liberator boats
JimboNoch
Mecklenburg NY
Got the WD hitch all setup and adjusted on our new Mallard M312IMG_20190724_192211549.jpg
Update: Just got back from our first weekend trip. Towed great considering it's size. Almost zero sway and it handled very nicely. Didn't stress the Ecobeast powertrain as much as I expected. Very very happy with the whole setup.
HawkX66
Semper Fi!
VA/MA
I took the 17 out for it's first real trip with my trailer. It towed beautifully. I left all the adjustments where I had them from my 07 and decided when I got back to recheck all the settings because it seemed to have a little too much tongue weight. I ended up tightening up the WDH levers when I got home a little and found it towed much better.
ccky
