Plastic (cracked) Valve Covers…Really Ford?
BlakeMAX2019
California
Took our 2019 MAX in for a couple recalls. Upon inspection, They notified me that we had cracked valve covers and another seal was bad. I’m beside myself that a car with 57kmi has cracked valve covers!? Really Ford…Really? I know many cars have plastic valve covers but this ridiculous….planned obsolescence…doesn’t matter if the 3.5 Ecoboost is strong engine that’ll last 200kmi…the cheap cooling lines, plastic parts everywhere, it’ll bankrupt you to keep it running to 200k. They want $2300 to do it. What is interesting is we had the oil/filter change in January and they never mentioned it?
Bmac1955
Southern Cali
Yes, poor decision on Ford cutting costs. If you have had since new and have not had the cam phasers done you will likely run into having that done at some point. I would seriously look into an extended warranty through Ford. It may be a costly item to purchase but Phasers and Trans repair might be the next item for you which are big ticket items. Fords design for parts are just set to failure at some point of vehicle lifetime. They save money with parts and yet fail after warranty period always leave owners with remorse.
99WhiteC5Coupe
The valve covers estimate and a seal estimate was $2,300? That seems like a very high estimate. What was the breakdown of parts and labor?
Being a cynic - I’d bet the valve covers were cracked before the power train warranty expired, and now the dealer can hose you on the repairs.
JamaicaJoe
Oviedo FL
Dealers everywhere, regardless of make, will puff up out of warranty repairs needed when doing recalls. Are you leaking any significant oil? Any oil smoking on the exhaust manifolds? Does the recall require them to open the valve covers?
SyndicateZ
Mass
My passenger side valve cover was cracked too. Its actually common issue . I only had 77,000 miles
BlakeMAX2019
BlakeMAX2019
California
Thanks for the comment, yes had since new, cam phasers and tranny were done at 30k or so. Looking back, should’ve got the extended warranty!
BlakeMAX2019
BlakeMAX2019
California
Agreed. Unfortunately This is not under warranty, we’ve owned since new. The recalls were unrelated to the valve covers, they just found it during their inspection. I check the oil and visual look over my cars weekly. I haven’t noticed any oil around the valve covers, smoking, but I haven’t really dove deep on looking either. I’ll check it out this morning in more depth to see what I come up with.
BlakeMAX2019
BlakeMAX2019
California
The $2300 is about right for the job I think, at least here in CA, most of it is labor according to the dealer.
Yeah, I often wonder the timing on these discoveries of repairs needed. I try to do weekly inspections on our cars so that I catch things that needs attention especially when they are still under warranty.
I just had the oil changed at the dealer 5 months ago and they didn’t mention any valve cover leaks, who knows if they actually did the inspection at that time. It wouldn’t have been under warranty at that time but still.
19platty
united states
Master ford technician here. I would ask your dealer to contact Ford for financial assistance. Since you are barely out of powertrain it is very likely they will assist. Also, this is a very common issue with the left hand valve cover leaking around the pcv connection. I have seen them leak without ever being removed. So it has nothing to do with over torquing or removing the valve cover. The reason there seems to be a correlation is because so many of them leak, and so many of them need phasers. One didn’t cause the other. With that being said, IF it’s the VCT solenoid seals leaking on the valve cover, it is possible if they didn’t replace them, they could be leaking from removal.
bb37
Member Relations Specialist
Indiana
Plastic valve covers? Say it ain't so!
An old friend used to work for a supplier to Cummins. They started using plastic valve covers, and plastic oil pans, on Cummins Diesel engines over 20 years ago.
Ford Tech Makuloco has talked about the plastic valve covers on the Ecoboost V6 engines failing, but I couldn't find a specific video where he covered it. I did find his "$6,000 Tune Up" video where he mentions the valve covers among all the parts he recommends replacing once your Ford engine gets up in miles.
BlakeMAX2019
BlakeMAX2019
California
Thanks for that insight. Yes it is the VCT seal on passenger side is leaking and the drivers side valve cover is cracked was the exact diagnosis. I appreciate the advice to contact Ford however it’s over a year after the powertrain warranty expired but the mileage is under 60k so maybe that would sway them to help? I take it to the dealer exclusively for all service and maintenance so this is the first time this issue came up, had an oil change 5 months ago and they didn’t mention it but maybe they didn’t do the inspection?
I trust the dealers but I do check their work. On the cam phaser fix, they under filled the oil by 1qt and on the Y-connect heater hose replacement they under filled the coolant, the reservoir was empty upon pick up.
BlakeMAX2019
BlakeMAX2019
California
IKR! I figured most companies have plastic everywhere these days. I guess I compare everything to my 20yr Toyota with 245kmi and no issues.
I’ll have to check out that video
BlakeMAX2019
BlakeMAX2019
California
If I look at it today to see how bad it’s leaking, any specific spots on the valve cover area I should focus on?
19platty
united states
If you have always serviced at ford there is a very good chance they may assist. I would definitely ask, you could also contact them directly if the dealer isn’t wanting to. I would ask about the vct seals being covered under service part warranty. Some of us take extreme pride in our work, but unfortunately some do not I would be embarrassed to perform a repair like some of the quality that I have seen from other techs.
