Please help - Coil replacement on the road
tkoden
Roxboro, Nc
Traveling and lost a coil. Looks like it's #6. I tried to get it out but it appears that the EGR or some other valve is in the way. What am I missing here? I'm on the road so I have limited tools. I'll probably lump to florance, sc.
Hamfisted
Ft Lauderdale
Do you mean that breather tube that's over #4 ? Push the grey plastic "clip" down out of it's groove and pull the elbow up and off the nipple.
Or the plug on the high pressure fuel pump over #6 ? Should have access after unplugging the fuel pump and move the plug harness out of the way.
T
tkoden
Roxboro, Nc
No, there was a wire over the #6 coil. I couldn't find a video on how to get it unclipped. I finally found someone who said how to disengage it.
