Plugs/COP's
khpony
SW Colorado
I just spent 6 hours changing them and does my expedition run nice now. 6 of the cop's were original and my truck just turned 160K! I worried over doing this for several months and now wished I'd done it earlier. I could probably do it in 2-3 hours if I had to do it again. It's not hard you just have to take your time. And yes you definately want to replace the o-rings on the injectors. Now I'm ready to tackle the slopy steering column.
K
khpony
SW Colorado
Several of my old ones had deteriorated some and a total cost of about $5 it just made sense with the fuel rails being removed.
IAExpy
Cedar Rapids, Iowa
+1 on the o rings. I changed my plugs last summer, didn't notice one had fallen off, and was SPRAYING gas when i turned the engine over. Spend the $5, you're under the hood anyway.
walnuts4x4
Watertown, NY
some people remove the rail for easier access to the plugs... I didn't have to when I changed mine
K
khpony
SW Colorado
On my 5.4 I didn't have any choice. No access with the rails installed. Suffered a cop misfire today. In line with the comments I've seen here on the ebay cop's. It's #8 and I'll change it in the morning. Having done them earlier this week and what I learned it shouldn't take but an hour or so. At least it wasn't #4!!
nordictom
Surf City, CA
Question, Is there a reason to change the COPS if they are not causing any problems? mileage limtations?
sorry for the hi-jack........
NT
walnuts4x4
Watertown, NY
if you aren't having any symptoms of a low grade miss or a CEL on I wouldn't change the COPs but then again if you feel like doing some preventative maintenance changing all COPs with plugs can only help... I used ebay coils from "global automotive" for almost 2 years now without a problem.... was under 100$ shipped for all 8... and for plugs I have autolite double platinums...
nordictom
Surf City, CA
I found the COP's on fleabay from GA, around $68 w/ free shipping. I'll put it on my to do list.
Thanks,
NT
Go4Life
Williamston, MI
KHPONY....What was your Expedition running like before you changed them? Mine runs sluggish and chugs as I'm driving. Bogs down until I give it more gas. Just curious!
gunslinger929
VA
good on ya, pony! did this myself a few weeks ago. I didn't have to remove the fuel rail, but it woulda made some of the angles easier. Mine was chugging at 50mph under load, Go4...
docraymund
philippines
Good afternoon, was reading your thread and I wanted to ask how did you change the plugs especially the ones at the very end, did you take off the hood or sat inside the engine bay? I was thinking of changing the plugs in my 4.6 2000 but am quite hesitant that I might not be able to do it. Thanks.
gunslinger929
VA
let the air out of the front tires... and use a knuckle on your socket extension.
