Gruz7
So I bought the truck (2006 XLT 5.4L) quite a few months ago and with the all terrain tires it has on it (40lbs each) it was getting about 13.4 MPG but the previous owner said it used to get to get 15-17 with those tires and he said because of the misfire it was getting less... So I said ok and got all new plug put in but not the coil pack. This seemed to basically fix the misfire but not the gas mileage, I was getting 12.8 MPG after the plugs were replaced and I then drive for a few months with the dash still reading about 12.8 MPG when I then put on the roof basket and reset the MPG and the new average was 12.2 MPG which I was fine with its a reasonable drop due to the resistance the basket causes. But a week ago I had a flat tire and had it plugged and put back and then reset the fuel economy again, 11.8 MPG. This morning I got in and drove to school and got home just now and it's reading 11.1 MPG. I do not consider myself an aggressive driver and I do try to drive sparingly for fuel sake but this atrocious... Since I bought it I've lost almost 3 MPG and I hear some people on here talking about getting 17 or 16 MPG and that isn't even close to me.
What I'm asking is can I diagnose this before I just go replacing odds and ends everywhere?
Some causes I think it could be or parts I think might need replacing are:
(Keep in mind these are all maybes as I'm not even close to sure where to start on this issue...)
Fuel filter
Fuel pump drivers module
PCV valve
Fuel pump
Coil pack
Catalytic converter
Air filter/CAI
Probably other thing that could be causing it but that's all I can possibly think of.
Any help is greatly appreciated because 11 MPG with stock tires and no lift is not good by any means.
Thanks
Fuel filter
PCV valve
Fuel pump
Coil pack
Catalytic converter
Air filter/CAI
Thanks
