Removal and Installation
CAUTION: To prevent possible damage to the third row seat or the safety belts, make sure that the safety belts are not fastened when moving the seat to the load floor position.
CAUTION: Make sure that no objects such as books, purses or briefcases on the floor in front of the third row seats or on the seat cushion before lowering the backrest(s).
NOTE: The third row seat backrests need to be in the raised position for removal of the third row seats.
All seats
Remove the load floor panel.
Remove the jack assembly.
Remove the load floor panel latch striker bolts and the latch striker.
Remove the 3 pin-type retainers and the jack storage compartment liner.
Remove the 2 bolts in mid-floor panel support, lift on the front of mid-floor panel support to release the 3 retainer clips and remove the panel support.
Power-fold seats with inoperative motor, backrest in down position
Using a suitable tool, insert it in the outboard side of the third row power seat motor. Raise the seat backrest.
Power-fold seats with seized motor or drive cable damaged, backrest in down position
Cut and remove the power seat drive cable.
Using a suitable tool, insert it into the drive gear assembly and raise the seat backrest.
Power-fold seats
Detach the wire harness pin-type retainer, disconnect the power fold seat motor electrical connector and remove the pivot bolt.
To install, tighten to 30 Nm (22 lb-ft).
All seats
Remove the seat-to-floor front bolt covers by opening rear tabs and slide cover forward.
Remove the 2 seat riser-to-floor front bolts.
Remove the 4 seat-to-floor rear bolts and remove the seat.
To install, tighten to 40 Nm (30 lb-ft).
To install, reverse the removal procedure.
Make sure the safety belts and buckles are accessible to the occupants after 60 percent seat installation.
Rear Seat Backrest — Third Row, 40 Percent
All seats
Remove the third row 40 percent seat. For additional information, refer to Rear Seat — Third Row in this section.
Remove the 2 screws and the inboard and outboard slide bracket covers.
Release the backrest trim cover lower and inboard J-clips.
Manual fold seat
Remove the manual seat cable.
Pinch the cable end and remove the cable from the retainer.
Release the cable end hook from the retaining hole.
All seats
Remove the outboard slide bracket-to-backrest frame and outboard slide bracket-to-outboard latch nuts.
To install, tighten to 15 Nm (11 lb-ft).
Remove the inboard slide bracket-to-backrest frame and inboard slide bracket-to-outboard latch nuts.
Remove the backrest from the cushion.
Rear Seat Backrest — Third Row, 60 Percent
All seats
Remove the third row 60 percent seat. For additional information, refer to Rear Seat — Third Row in this section.
Manual fold seats
Pinch the cable end and remove the cable from retainer.
All seats
