Power Distribution Relay Issue
J
JunkyardDog
Cypress, TX
Hey, you did good! I used a bunch of old fuse box circuit expanders that were reformed and able to be used on the old glass fuses (picture attached.) We used to use them to add stereos back in the day when extra circuits were not available.
(I apologize for not replying promptly. Life threw me a bunch of curves. One of the curves was a computer crash!)
2003FordGuy
Southern Cali
Computer crash? That's right up my alley. I'm a PC Repairman. Lol. Yeah man. The mod is holding up great. Not long ago, about 8 months ago I had to desolder the fuel pump relay from the circuit board and solder in a new FP relay. Quite a headache. But I got the job done.
1955moose
Curious, was the fuel pump relay the only one soldered in? Or were they all soldered in?
TobyU
Ohio
Sounds like the OP beefed it up and it worked. That's what would do the first time. Sometimes I solder a jumper wire or run wire along the trace to beef it up a lot.
If later failure I would just solder wires to the terminal pads on the board and run wires to the outside to a full size 4 or 5 prong relay holder and glue it to side of module box.
WeldXMachina
Edit- I see now that there is no clip on the Distro Board for Pin 4, disregard question
I know this is an old thread, but I see you're still active in this forum. I've got the blades but haven't bought the Bosch style socket yet because I have a simple question:
Is Pin 4 on the block just not used? I realized that this mod only uses 4 pins and just wanted to make sure I understand.
I can *somewhat* make out wiring schematics with a lot of mental work, but it's not my strong point.
FixOrRepairDaily
Hell
I’m currently experiencing this very problem and I’ve seen SOOOOO many others going or gone through it so why is there no recall on it?!
Budman55
