jlo82585
hey guys, I have a 2002 expedition that I have been fixing up for about a month now. I recently installed a new fuel pump assembly and I am getting an odd issue. the best way to describe it is basically a complete loss of power when you a turning left, but only when you are turning at higher speeds sharply or turning sharp and gassing the engine. I cant reproduce the issue under normal driving so the only time its an issue is when you pull out in front of a semi or something and you need to accelerate very quickly. while in the turn the engine will totally cut out, not miss or shudder. the RPM will start falling and there is no power to the wheels. as soon as the truck starts to shift its weight back to the center the power comes right back and the truck acts normal. the only code being thrown is for the evap pressure sensor. which is a wiring issue. the fuel pump is new so I doubt its that, any ideas? I am at a total loss.
