power seat issue
Hman
Westwood, NJ
Hi folks, I have an 04 Eddie Bauer. The driver power seat as well as the adjustable pedals and power mirrors do not work. They are on the same fuse and the fuse checks out to be ok. The seat had been working sporadically but now nothing. It seems to be a power issue but don't know where to start and I welcome any ideas, thanks.
Bedrck47
Elizebethtown, PA
can you read and understand wiring diagrams
also I notice your profile has 1999 listed kindly update if that is wrong
Bedrck47
Elizebethtown, PA
which fuse/s did you check and how did you check them
also do you have the memory seats, pedals and mirrors
H
Hman
Westwood, NJ
I checked the main fuse panel on the passenger side, the diagram in the manual says its a 30 amp fuse. I did not pull it as the wire in the fuse looked fine and yes, I do have the memory seats, pedals and mirrors. I am a builder and read plans all day, wireing diagrams might be a different story. Thanks for the reply and I will update my info, the 99 is gone.
Bedrck47
Elizebethtown, PA
Not to insult you but just looking at a fuse does not tell the same as reading it with a test light or more preferred use a meter. Looking at a fuse is just like looking at your battery when the vehicle won't start and saying It looks good.
The fuse you looked at most likely was #109 30 amp. There also is another fuse in the circuit which is #3 7.5 amp Have both fuses tested and post your findings
