It’s a super easy oil change. The felt belly pan comes off with 4 8mm bolts to access the drain plug. There’s nothing to take off to access the oil filter. My advice is to get the engine warm, but not hot. As other have said, spin the filter off slowly and it will all drain out the back of the filter drain trough. There’s a hole in the metal undercover for the oil to go through. If your vehicle is level, it will go right through the hole and not make any mess. As for the drain plug, I recommend you loosen the plug, then hold the drain pan up near the vehicle with your other hand. Get the plug out, then lower the drain pan as the oil is flowing. This prevents any oil spraying all over the place. As for oil and filter, I use Motorcraft 5w30 Synthetic Blend and a Motorcraft FL500S Oil Filter and change them every 5k miles. They can both be purchased at Walmart for a really reasonable price. I never spill a drop and with a little patience and strategy, you won’t either.
