Question about wiring
NC-Expy
Apex, NC
I purchased a set of ebay strobe lights (they are pretty bright for 15 bucks!!!) and they came with a control box that I wired straight to my battery...
my question is... I also ordered a set of rocker switches to mount in my center console and I was wondering if and how I can wire the control box to one of the switches?
So basically I want to be able to switch on the strobes via the switch with the control box in between.
Newport News, VA
THERMO and alaskanexpy should be all over this one...alaskanexpy is a hwy operator and installed all sorts of lights/strobes in his trucks so he will know for sure...THERMO is the electrical expert in the forum....they'll set you straight if no one else hooks you up by then...g/l
BakerEdition
EF Chaplain
Yes they are..but still cant figure out how to turn my dome lights on...JK..LOL
callee11
Elk city Ok
If there is just one power wire that controls the box all you have to do is run a wire from the battery (with inline fuse) up to the switch then run a wire from the other side of the switch over to the control box.
NC-Expy
NC-Expy
Apex, NC
Thanks for clarifying that, I will be doing this once I get the switches in the mail.
Thermo
technical advisor
Just as Callee said. Granted, make sure you are using a switch that is rated for the current of the control box. You may find it easier to use a relay in this case, especially if the control box is going to pull over 10 amps. If you need me to make up a wiring diagram for you, I will. NOthing fancy. Even a person with basic wiring abilities can make this sort of circuit.
