Question for you all
Tomringler
Hopkinsville, ky
Just got a 06 Eddie Bauer expedition the other day and while driving I have notice every once and while that when I make turns and give it some gas it feels like the wheels or something Is engage then it stops. Any suggestions would be helpful.
1997SCEBFEX
Northwest Panhandle
how hard of a turn induces this, gradual, or hard, or all the time?
does speed make any difference?
what rear diff do you have?
i'm sure you checked, but is your emerg brake dragging?
how many miles, any idea of major services recently completed?
PanHandler.
FordandPolaris
Saint Cloud, MN
If it is in 2wd, then my first suspect would be a CV joint. When those go bad, you feel kind of a catch from one side of the vehicle in front. Examine the CV boots for holes. Those almost always show a bad joint cause it gets dirt in there and no longer works effectively. Does it produce the condition turning both left and right?
Kansas City
My 06 EB does the exact same thing, and it's been getting worse over the last few months. It feels like it's in 4WD. I've done a little research (which led me to this forum) and quite possibly this is a bad IWE solenoid?
mindgame
Honolulu, Hawaii
This is a quick fix. 5-10 minutes to replace.. and approx. $40.
Replacing the half shafts will take time to replace, plus make sure you got a torque wrench....
:head3:
T
Tomringler
Hopkinsville, ky
1997SCEBFEX it seems like it doesn't matter on kind of turn it seems to do it when I accelerate. All I know is I have 3.73 gears by the build sheet. About 130,000 and don't know about any services.
ExpeditionAndy
Fort Wayne, Indiana
What is the iwe solenoid and what does it do
The IWE solenoid engages the hubs when you put it in 4WD or AWD.
On the expedition the only the wheels rotate when you are in 2WD the axles and transfer case do not turn. When you engage the AWD or 4WD the solenoid allows the hubs to engage and drive the wheels.
I know that is not a technically accurate explanation but it should explain it.
mindgame
Honolulu, Hawaii
Actually.. This is slightly true..
The front driveshaft and TC are engaged and spinning in all modes while driving.
By having the TC/DS spinning, this will allow you to switch from 2WD to 4AWD to 4H while driving at speeds like 60+mph. If this was not spinning, just imagine the torque going to the TC from dead stop while the car is running at high speeds. I'm pretty sure the TC will be trashed.
While in 2WD and the TC/DS are spinning matching the spin of the wheels, engaging and disengaging the hubs are obtainable via vacuum. At matched speeds the hub actuator and CV spline will not bind thus allowing simple hub engagement/disengagement via simple vacuum is a snap.
:head3:
eddiebauer04
When is the last time you changed the rear diff fluid. I had a problem with my 2004 doing about what your talking about especially when accelerating. I changed the fluid and added two bottles of the friction modifier and I was good.
mindgame
Honolulu, Hawaii
I thought the 2nd gen Expeditions have this: Ford F150 - 4 Wheel Drive Disconnect - YouTube
The guy clearly states that the half shafts don't turn until engaged.
Some times the easiest way to see things is to just jack the truck on four jack stands and let the wheels spin and test each mode 2WD/AWD/4H..
You will see that the front shaft/TC is spinning regardless of which mode you set. The hub actuators will be disengaged only if there is a vacuum present. No vacuum, hub are engaged by default.
:head3:
sgtowing
Supporting Members
Valrico, Fl
Does yours have the LSD? Mine is 4x4 buy when I bought it, when I would go around a turn, it would feel like it was binding up. I took it to the dealer and they said it was the LS in the rear end. The clutch was binding up. They replaced the fluid in the rear and that fixed the problem. there is some special kind of additive in the fluid that the clutch pack need or it starts acting up.
Kansas City
I talked with a mechanic whom I've dealt with before and he said that he one time worked on an Expedition that actually had dry rot on the vacuum lines which led to the grinding/clunking that I'm experiencing. he thinks that's probably it and not necessarily (just) the solenoid. Does that sound plausible? I'm going to take it to him next weekend so I'll report back what they actually find.
T
Tomringler
Hopkinsville, ky
Don't know when any fluid changes where done just got it 1-20-2014, don't know if it has LSD or not
It is at the shop when they call me and let me know I will let y'all know
jdecker
Lawrence, KS
Your mechanic is correct, it could be a vacuum leak. Check all the lines also the IWE itself could be leaking and there is also a vacuum reservoir that can leak. It can also be a bad vacuum check valve.
btw- if your front drive shaft is spinning while in 2wd mode your transfer case isn't unlocking as it should
