Sure. Did you get an alignment after the work?
Also, are you certain tie rods were installed correctly? I ask specifically because I've seen posts where someone installed the end from the wrong side.
I have not gotten an alignment, but plan to do so. Last year after I had replaced several suspension components I did have an alignment. The shop said they couldn't get the camber correct on one side and needed to install a camber kit. I did not have them do that, as I wanted to research it, but am still confused about it. LOL. The previous owner hit a deer on the side that needs the camber kit, so I wonder if the impact bent something?
As for the tie rods, they did come installed in the reman rack from Detroit Axle, so I assume they'd be correct? Also when I removed the tie rod ends from the old rack, I counted the turns to install in approximately the same spot. HOWEVER one side was 22 turns and the other was 27 turns.
Thanks for the input.
